Hi All,
I am a newbie in UVM verification methodology. please help me out with this error. I tried to debug at my best but still i am missing something. i am running simple spi_read_write test and i am getting the below error.
*E,TOOMAC (/cad/adi/apps/cadence/incisive/linux/15.10-s14/tools/methodology/UVM/CDNS-1.1d/sv/src/base/uvm_registry.svh,66|12): Too many actual arguments.
function new(string name = “read_write_seq”);
ncelab: *E,TOOMA2 Task or function definition (or class definition) for previous error message.----error from my sequence class
My sequence code:
class read_write_seq extends spi_slave_tb_vseq;
`uvm_object_utils(read_write_seq)
spi_slave_base_seq p_seq;
super.new(name);
endfunction : new
virtual task body();
for(int i=0;i<10;i++)begin
uvm_do_on_with(p_seq,p_sequencer,{_spi_cmd inside {SINGLE_WRITE_INSTR};}) #100ns; uvm_do_on_with(p_seq,p_sequencer,{_spi_cmd inside {SINGLE_READ_INSTR};})
endtask: body
endclass: read_write_seq
My test code:
class read_write_test extends spi_slave_tb_base_test;
read_write_seq seq;
`uvm_component_utils (read_write_seq)
// Constructor
function new(string name = “read_write_test”, uvm_component parent = null);
super.new(name, parent);
endfunction : new
// Build phase
super.build_phase(phase);
// Create the virtual sequence
seq = read_write_seq::type_id::create(“seq”, this);
void’(seq.randomize());
endfunction : build_phase
// Main phase
virtual task main_phase(uvm_phase phase);
super.main_phase(phase);
`uvm_info(“START_SEQ”, “Invoking read_write_seq”, UVM_LOW)
seq.starting_phase = phase;
// Start the virtual sequence on the virtual sequencer
seq.start(env.vsqr);
endtask : main_phase
endclass : read_write_test
Debugging this error has become tough as it is not showing much of clarity. Is anypne has idea on this?
