To Check The EDA Tool's Version
How to check the version of/The command to check the Version of different EDA tools(Synopsys-VCS, Mentor Graphics-Questasim, Cadence-ius) in Linux Terminal?
Hmmm, have you tried -version?
Hi Dave_59,
Thanks for your concern.
Yes I’ve tried with -version but it’s also not working.
For VCS, we normally use the command which vcs.
Similarly, I want the command for QuestaSim & ModelSim & ius**(Cadence)**.
In reply to psp127143:
% vsim -version
Questa Sim  vsim 10.2a Simulator 2013.03 Mar 15 2013
you can simply write
$which vcs
synopsys/vcs/**2012.09**/bin/vcs
is your VCS version no.
Or you can use -v switch which prints VCS compile and run-time version numbers, and copyright information, at start of simulation which you can check in log file.
Thanks a Lot Dave.
It’s working fine…!!!
In reply to Vinay Jain:
Thanks Vinay for your concern.
Yes for VCS its working fine. But for Questasim what is the command to check the version do you know?
As per Dave,vsim -version is working fine. Is there any other way to check?
Also I need to check the version of ius(cadence). So do you know how to check?
Thanks in Advance…
