Hello,
I have a fundamental question about using RAL.
In the reference, The general sequence task can be repleaced to RAL sequence as below.
//General Sequence task
virtual task body();
`uvm_do_with(req, {addr==’h0; kind==UMV_READ;});
`uvm_do_with(req, {addr==’h4009; data==’1; kind==UVM_WRITE;});
// RAL Sequence
virtual task body(); uvm_status_e status; uvm_reg_data_t data;
regmodel.HOST_ID.read(status, data, .parent(this)); // can specify .path
regmodel.RAM.write(status, 9, ’1, .parent(this)); // defaults to frontdoor
The general sequence task consumes time duration (clocks) for bus signaling to read/write data.
However RAL sequence dess not consume the time, since it calls functions by regmodel adapter and regmodel.
Then how we verify the acutal read/write bus operation and time dependant simulation flags in RAL?
