Hello,
I am new to systemverilog and I am curious about the time efficiency of the operations of arrays/queues/associative arrays/ dynamic arrays in SV.
For example,
- what is the time complexity of using built-in function insert() to insert an element to the middle of a SV queue? (
void insert (input integer index, input element_t item);
2. What is the time complexity of using the SV associative array method
find_index()
Also, I would like to know if there are any resources/tutorials/websites that I can use to learn the time complexity of some basic manipulations of different SV data structures. I have tried SystemVerilog LRM but got somewhat overwhelmed.
Is the calculation of time/space efficiency basically the same as in Java/C++?
Any tips would be appreciated!
Thank you very much!
