Time checking sequence
In reply to emin:
A simple error, the TB never clocked because
logic clk; // is initialized to x
COde works OK; made simple mods
module tb;
    bit clk;
    realtime delay = 50ms;
    function automatic bit check_time();
      // $display("running check time %t", $realtime);
      return ($realtime > delay) ? 1'b1 : 1'b0;
    localparam CLK_PERIOD = 1ms;
    // always #(CLK_PERIOD/2) clk=!clk;
    initial forever #10 clk=!clk;
        #100ms $finish;
    sequence check_time_s;
        bit res;
        (1, res = check_time()) ##0 (res == 1'b1);
    endsequence
    property check_time_p;
        @(posedge clk) check_time_s |-> 1;
    check_delay: assert property(check_time_p) // $display("@t %t PASS", $realtime);
        else $error("Assertion label failed!");
    Real Chip Design and Verification Using Verilog and VHDL($3) Amazon.com
  3. Papers:
