could you please clarify how to check whether a signal “a” is zero through out reset .could you please clarify which one of the following is true
example 1
a==0 throughout reset==0;
example 2
a==0 throughout reset==0[*1:$];
example 1
example 2
In reply to srbeeram:
1800'17: F.3.4.2.4 Other derived operators
( b throughout R ) is_same_as (( b [*0:$]) intersect R )
// A BAD property
!a throughout reset==0[*1:$]);
// Above is same as
!a throughout reset==0[*1] or // This alone satisfies the property
reset==0[*2] or
reset==0[*n]);
// You need as a consequent the following
!a throughout reset==1[->1]);
// or the following
!a[*0:$] intersect reset==1[->1]);
// HOWEVER, you need an antecedent or an initial if reset==0 from the start
// For example:
initial if(reset==0)
ap_a_reset_OK: assert property(@ (posedge clk)
ap_a_reset_OK2: assert property(@ (posedge clk)
// You could also use $fell(reset) as antecedent if there is a fell
thanks ben for the reply
the following checks !a when reset=1 also. but I have to check !a until reset==0 . could you please clarify how to do it
// or the following
My code is correct. Instead of feeding you the answer, as a teacher, I would rather that you
study the goto [->n] repetition (nonconsecutive exact repetition); it’s in 1800
As a homework for you, please tell me what is the equivalent of b[->1]. You owe that much since I gave you the correct answer.
A note in the case you want to check that property more than once
logic reset=1'b1;
ap_a_reset_OK3: assert property(@ (posedge clk)
$fell(reset) |-> !a[*0:$] intersect reset==1[->1]);
// alternative
$fell(reset) |-> !a throughout reset==1[->1]);
