I have two threads which should be cross-talk each other, but each thread has different working period.
When I put those two in single fork as below, as assumed new “seq_ready” thread can not be started before “incrx_seq” is finished.
repeat(10) begin
seq_ready.start(env_h.slv_agnt.slv_seqr);
incrx_seq.start(env_h.mst_agnt.mseqr_h);
join
The log says below.
10: seq_ready Start <<<
10: incrx_seq Start <<<
10: seq_ready.ready.size: 7 <<< // OK
150: seq_ready Done <<<
150: seq_ready Start <<< // “seq_ready” invoked, but no proceeding
330: incrx_seq Done <<<
330: seq_ready.ready.size: 12 <<< // THIS SHOULD BE STARTED AT @150
What I want is “seq_ready” should be restarted as it finished regardless incrx_seq status.
How can I resolve this problem?
Update…
It looks very strange…
The task in slv_seqr has
forever begin
$display (">>> %05t: Slave Seq begin <<<", $time);
$display (">>> %05t: Slave get_next_item <<<", $time);
begin: drv
drive();
disable rst;
begin: rst
reset_();
disable drv;
join
seq_item_port.item_done(req);
$display (">>> %05t: Slave Seq Done <<<", $time);
The log was
>>> 150: Slave Seq begin <<<
>>> 330: Slave get_next_item <<< // Why "get_next_item" elapse time even after the task was started?
I don’t see how your are getting this output with the code you have shown. You may want to try source level debugging if that is available to you. Also, it’s possible you meant to write
