Hi All,
am getting following warning when i use simopts with constraints.
code:
rand int num;
constraint num_c {
num inside {[1:6]};}
super.build_phase(phase);
if($value$plusargs("num=%d",num)) begin
`uvm_info(get_full_name(), $sformatf("num set from cmdline %d",num), UVM_MEDIUM);
cfg.randomize() with { chn[num] == INPUT;} ; //randomize the configuration object
endfunction : build_phase
Warning:
The randomize method call failed. The unique id of the failed randomize call is 25.
Please help me
