I have successfully simulated and incorporated the learnings from AgileSOC and the presentation about SVUnit test in edaplayground.
When I try the examples about UVM Unit Tests I run into issues.
- The examples in AgileSoC are very limited and stale.
- The examples in edaplayground are with UVM1.1. Does it mean that we can’t test newer versions? Some examples do not work.
A broad question: Does anyone use UVM-UTest in their flow?
If you use, where can I find current examples?
I am not sure that SVUnit by itself is worth much as we are in UVM environment and we can’t connect the components for testing.
Here is what I know:
