Morning all,
death match with the register abstraction layer continues!
After giving up on the bit bash sequences (poor uvm implmementation of reserved fields) i have written my own access test.
I am now curious about testing read only register.
For example, if we have a version register used to indicate the version of hdl code.
From a register perspective this would be like holding its inputs at set levels forever and ever. If i was to create a test to ensure the read only capability of the register i would create a backdoor write or poke then a front door read?
So what if i want to change the read-only register from the other side of the register? These are only status pins or hardcoded pins. Can i use the back door for one cycle?
I know want to create another uvc just for two or three pins.
Any thoughts?
Hi Phill,
Of course you can use the backdoor access to these register’s. Indeed the backdoor_write function is available for Read-Only registers.
Just you need to make sure that hdl_path is correct.
Vaibhav
In reply to Vaibhav Tekale:
Vaibhav,
thanks for getting back to me.
The problem i have is that if the pins are hard coded, the backdoor poke (or write) only forces the signals to what i want for a clock cycle until the input pins are re-assigned.
This also applies to registers that are RO on the software side and WO on the hardware side.
What does backdoor_write do that is different from write or poke?
Ok well i guess i answered my own questions again.
The truth is that via the register model you can only test the sw interface.
Unless i have another UVC to drive the pins from the register block there is no point in the approach above.
if i back door write, the data will be over written on the next clock with the data actually on the pins of the register.
The answer was to change how i tested the read only side of the register.
