I have this task that just reads a bunch of memory addresses and writes the data to a file (this task appears to be working). I added some $display statments to see what time it starts at and what time it finishes at, and it appears to start and finish at the same simulation time. There is a for loop in here that loops through >4000 times. Shouldn’t this take some amount of time in the simulation? Not sure how this part works exactly. Here is the code for the loop:
if (i_yuv_format != 1'b1) begin
for (int i = 0; i < (i_frame_width*i_frame_height); i=i+1) begin
this.vps_if.task_read_mem((i_mem_addr + (8*i)), 8, read_mem);
$fwrite(i_file_handler, "%u", read_mem);
else begin
$display("[%0t]: Starting dump_ddr_to_file task", $time); // added this for debugging
for (int i = 0; i < ((i_frame_width*i_frame_height*2)/8); i=i+1) begin
$display("[%0t]: Finished dump_ddr_to_file task", $time); // added this for debugging
Here is what I see on the console:
[385500 ns]: Starting dump_ddr_to_file task
[385500 ns]: Finished dump_ddr_to_file task
