Task static vs. task automatic
According to the LRM Section 5.5, the default qualifier for lifetime is static.
But the following code seems to be a counter-example.
Anyone can help on this?
Thanks.
If declare the wait_and_echo() as
 task wait_and_echo();
OR
 task automatic wait_and_echo();
then the output will be
obj name: B, value: 00000001
obj name: B, value: 00000002
obj name: A, value: 00000001
obj name: A, value: 00000002
task static wait_and_echo();
then the output is,
obj name: A, value: 00000003
obj name: A, value: 00000004
Code
class A;
   int value;
   string name;
   function new(string s);
      name = s;
      value = 0;
   endfunction // new
   function void build();
         wait_and_echo();
         wait_and_echo();
      join_none;
   endfunction; // build
   //task automatic wait_and_echo();
   //task static wait_and_echo();
      //wait($time == 1000);
      #1000;
      value++;
      $display("obj name: %h, value: %h", this.name, value);
   endtask // wait_and_echo
endclass; // A
class B extends A;
      super.new(s);
   endfunction // new
endclass; // B
      A a_h;
      B b_h;
      a_h = new("A");
      a_h.build();
      b_h = new("B");
      b_h.build();
      #2000;
endmodule // top
Tasks and functions that are class members are declared automatic by default.
In reply to ocmob:
See what is the exact difference between static tasks/functions and automatic tasks/functions ? please explain with a clear example | Verification Academy
Thanks Ocmob & Dave!
So it is illegal to declare the lifetime as static for methods in class, though it mignt not issue any error. (I tried the example with Questasim 10.2c)
