I have a lock-up problem with my UART receiver project. For each character received I go through 4 states RX_IDLE, RX_GETSTART, RX_GETDATA and RX_STOP. The RX_IDLE state waits for the incoming signal to fall from high to low using my FallingEdgeDetector.
FallingEdgeDetector latches (stops running) once it detects a falling edge and I have to bring a reset input high to get it to look for another falling edge.
The attached image shows the “running” output of my FallingEdgeDetector completely flat-lining. I don’t understand how this is happening because the only time ‘running’ is set to 0 is when a falling edge is detected and the fallDetected output should be 1 at the same time. However, ‘fallDetected’ is 0 and so is ‘running’. They should always be the opposite to each other.
How could this be happening? I’ve tried using different output pins on my FGPA development board - including routing the ‘running’ output to one of the onboard LEDs. Same thing. It will receive sometimes tens or hundreds of characters and then it freezes.
I’ve tried to minimise the project as much as possible.
FallingEdgeDetector:
module FallingEdgeDetector( input logic clk,
input logic rxIn,
input logic reset,
output logic fallDetected,
output logic running
logic rxLast;
running = 1;
rxLast = 0;
fallDetected = 0;
always_ff @( posedge clk )
if( reset )
running = 1;
rxLast = 0;
fallDetected = 0;
if( running )
if( ( rxLast ) && ( ! rxIn ) )
fallDetected = 1;
running = 0;
rxLast = rxIn;
Baud Tick Generator:
module UART_BaudRate_generator #(parameter longint BaudRate=19200) // Bits per second
input Clk,
output logic TickX8 // 8 ticks per baud cycle
localparam longint freqFPGA = 50000000; // 50MHz
longint BaudRateX8Clocks;
longint currClock8Count;
initial
if( BaudRate == 9600 )
// Number of FPGA clock cycles requires for 1 baud period
// BaudRateClocks = freqFPGA / BaudRate;
BaudRateX8Clocks = 372;
TickX8 = 0;
currClock8Count = 0;
always @(posedge Clk)
if( currClock8Count >= BaudRateX8Clocks )
TickX8 = 1;
TickX8 = 0;
currClock8Count ++;
CharacterReceiver:
module CharacterReceiver( input logic rxIn,
input logic baudTickX8,
input logic clk,
output byte rxData,
output logic ledBit1,
output logic ledBit2,
output logic ledBit3,
output logic ledBit4,
output logic ledBit5,
output logic ledBit6,
output logic ledBit7,
output logic ledBit8,
output logic ledBitStart,
output logic ledBitStop,
output logic ledPurpleIdle,
output logic ledPurpleStart,
output logic ledPurpleData,
output logic ledPurpleStop,
output logic ledPurpleDetected,
output logic ledPurpleDetectReset,
output logic detectorRunning
byte unsigned bitsRemaining = 0;
byte unsigned currentChar = 0;
byte unsigned sampleCount;
byte unsigned sampleSize = 14;
byte unsigned halfSampleSize;
byte unsigned matchCount = 0;
localparam byte detectResetCyclesMax = 50;
assign ledPurpleDetectReset = fallDetectorReset;
assign ledPurpleDetected = fallDetected;
initial
halfSampleSize = 8;
currentChar <= 0;
bitsRemaining <= 8;
sampleCount <= 0;
ledBit1 <= 0;
ledBit2 <= 0;
ledBit3 <= 0;
ledBit4 <= 0;
ledBit5 <= 0;
ledBit6 <= 0;
ledBit7 <= 0;
ledBit8 <= 0;
ledBitStart <= 0;
ledBitStop <= 0;
logic fallDetectorReset = 1;
logic fallDetected;
FallingEdgeDetector fallingDetector( clk,
rxIn,
fallDetectorReset,
fallDetected,
detectorRunning );
// Receive States
typedef enum
RX_IDLE,
RX_GETSTART,
RX_GETDATA,
RX_GETSTOP
} RECEIVESTATE;
RECEIVESTATE rxState = RX_IDLE;
// HandleRxGetStart
function void HandleRxGetStart;
if( rxIn == 0 )
matchCount ++;
if( rxIn == 1 )
sampleCount = 0;
rxState = RX_IDLE;
detectResetCycles = detectResetCyclesMax;
matchCount = 0;
// We only want to count half of the baud samples to put us in the middle..
//if( sampleCount < halfSampleSize )
if( matchCount < halfSampleSize )
return;
// Start counting samples from the middle..
sampleCount = 0;
matchCount = 0;
bitsRemaining = 8;
ledBitStart = 1;
ledBitStop = 0;
rxState = RX_GETDATA;
// HandleRxGetData
function void HandleRxGetData;
bit bitVal;
// Wait sampleCount X8 ticks since the middle of the start bit.. or
// sampleCount X8 ticks since the last bit..
if( sampleCount < sampleSize )
return;
// Reset count for next time..
sampleCount = 0;
unique case ( bitsRemaining )
8: currentChar = currentChar | ( rxIn ? 8'h01 : 1'b0 );
7: currentChar = currentChar | ( rxIn ? 8'h02 : 1'b0 );
6: currentChar = currentChar | ( rxIn ? 8'h04 : 1'b0 );
5: currentChar = currentChar | ( rxIn ? 8'h08 : 1'b0 );
4: currentChar = currentChar | ( rxIn ? 8'h10 : 1'b0 );
3: currentChar = currentChar | ( rxIn ? 8'h20 : 1'b0 );
2: currentChar = currentChar | ( rxIn ? 8'h40 : 1'b0 );
1: currentChar = currentChar | ( rxIn ? 8'h80 : 1'b0 );
0: ;
endcase
8: ledBit1 = rxIn;
7: ledBit2 = rxIn;
6: ledBit3 = rxIn;
5: ledBit4 = rxIn;
4: ledBit5 = rxIn;
3: ledBit6 = rxIn;
2: ledBit7 = rxIn;
1: ledBit8 = rxIn;
0: ;
endcase
bitsRemaining --;
if( bitsRemaining <= 0 )
// Ready for next time..
bitsRemaining = 8;
rxState = RX_GETSTOP;
// HandleRxGetStopBit
function void HandleRxGetStopBit;
return;
if( rxIn == 1 )
ledBitStop = 1;
ledBitStart = 0;
sampleCount = 0;
rxState = RX_IDLE;
byte detectResetCycles = 0;
// State machine for receiving
ledPurpleIdle = ( rxState == RX_IDLE );
ledPurpleStart = ( rxState == RX_GETSTART );
ledPurpleData = ( rxState == RX_GETDATA );
ledPurpleStop = ( rxState == RX_GETSTOP );
if( rxState == RX_IDLE )
if( fallDetectorReset )
if( detectResetCycles > 0 )
detectResetCycles --;
// Leave the reset signal up for a number of clock cycles
// Clear this now - only needs to be high for 1 clock cycle
fallDetectorReset = 0;
if( fallDetected )
ledBitStart = 0;
ledBitStop = 0;
rxState = RX_GETSTART;
// Don't include transition, get next time
// Service state machine for receiving
if( ( rxState != RX_IDLE ) && ( baudTickX8 ) )
sampleCount ++;
sampleCount = 0;
// WARNING!! If you don't add ALL cases, the wrong case will execute instead!!
unique case( rxState )
RX_IDLE : ; // MUST have this!!
RX_GETSTART : HandleRxGetStart();
RX_GETDATA : HandleRxGetData();
RX_GETSTOP : HandleRxGetStopBit();
endcase
Testbench:
module SystemVerilogTest1( input logic clk,
input logic i115,
output logic baudTickX8,
output logic txActual,
byte rxByte;
parameter longint baudRate = 9600;
UART_BaudRate_generator #(baudRate) BaudGen1(
.Clk( clk ),
.TickX8( baudTickX8 ),
CharacterReceiver charReceiver( i115, baudTickX8, clk,
rxByte,
ledBit1,
ledBit2,
ledBit3,
ledBit4,
ledBit5,
ledBit6,
ledBit7,
ledBit8,
ledBitStart,
ledBitStop,
ledPurpleIdle,
ledPurpleStart,
ledPurpleData,
ledPurpleStop,
ledPurpleDetected,
detectorRunning
