Hi all,
Just another question on Implicit Constraints
Here’s the current situation on the Constraint and the following classes that I have currently written.
class the_address;
rand bit [31:0] addr;
endclass : the_address
typedef enum {BRANCH, LOAD, STORE, IMM} opcode;
class decode extends the_address;
rand opcode opcode_num;
constraint find_opcode
// using the enum opcode as the condition - shows correct
if (opcode_num == BRANCH) addr[6:0] == {7'b1100011};
else if (opcode_num == LOAD) addr[6:0] == {7'b0000011};
else if (opcode_num == STORE) addr[6:0] == {7'b0100011};
else if (opcode_num == IMM) addr[6:0] == {7'b0010011};
endclass : decode
decode bit32;
bit32 = new;
repeat(10) begin
if(bit32.randomize() == 1)
$display("%b Opcode: %s\n", bit32.addr[6:0], bit32.opcode_num);
$display("RANDOMIZATION FAILED \n");
$finish;
It does show the correct result that I desire as shown below:
1100011 Opcode: BRANCH
0100011 Opcode: STORE
0000011 Opcode: LOAD
However, when I make some changes on the constraint - such as:
if (addr[6:0] == 7'b1100011) opcode_num == BRANCH;
if (addr[6:0] == 7'b0000011) opcode_num == LOAD;
if (addr[6:0] == 7'b0100011) opcode_num == STORE;
if (addr[6:0] == 7'b0010011) opcode_num == IMM;
endclass : decode
The result I get is the following:
1111111 Opcode: IMM
0111011 Opcode: IMM
0100010 Opcode: STORE
0001110 Opcode: BRANCH
0100000 Opcode: STORE
1001000 Opcode: LOAD
Is there something that I am doing off? I even tried putting a bidirectional constraint operator on the first constraint that I have used, and it still shows the correct result. The only reason why I tried the second constraint method is to show that if the bidirectional equivalence works, then the constraint should show the same result both ways.
Any help or tips would be appreciated.
Sangwoo.
