Systemverilog assertion
In reply to wangjiawen:
  • (B[->1] && C[->1]):
    You need to use the sequential andoperator instead of the logical **&&**operator since B[->1] and C[->1] are sequences
  • You need to use an implication operator because at every clocking event you have an attempt. Using only a sequence as the property of an assertion the assertion fails when an element of the sequence is false. In this case, every time A==0 the assertion fails instead of being vacuous (your real intent).
/* signal A asserts for one cycle, then signal B asserts for one cycle and signal C
 asserts for one cycle(The problem here is: the order of B and C is arbitrary,
 so we don't know when B and C will be asserted and who will be asserted first),
 then signal D should asserts right after the latter one of B/C */
 module m;
	bit clk, a, b, c, d;
    ap_abc: assert property(@(posedge clk)
	         a |-> (b[->1] and c[->1]) ##1 d);
 endmodule : m
    Real Chip Design and Verification Using Verilog and VHDL($3) Amazon.com
  3. Papers:
