i have to create a packet consist of 3 dynamic array arrays a,b and c such that each of 8 bit and size between 15 to 25.
the value in the arrays is 1 to 200.
the values in array a and b must not be same and the result of the values of a and b array must be saved in c array but in reverse order.
the odd numbers and not used in first array and the even numbers are used in second array.
this has to be done my randomization
// Code your testbench here
// or browse Examples
// I have to create a packet consist of 3 dynamic array arrays a,b and c such that each of 8 bit and size between 15 to 25.
//the value in the arrays is 1 to 200.
//the values in array a and b must not be same and the result of the values of a and b array must be saved in c array but in reverse order.
//the odd numbers and not used in first array and the even numbers are used in second array.
//this has to be done my randomization
module tb;
class Packet;
rand bit [7:0] a[],b[],c[];
constraint size_abc {a.size inside {[15:25]};b.size inside {[15:25]};
c.size inside {[15:25]} ;}
constraint value_a { foreach (a[i])
a[i] inside {[1:100]};}
constraint value_a_even {foreach (a[i])
a[i]%2==0;}
constraint value_b { foreach (b[i])
b[i] inside {[1:100]};}
constraint value_a_odd {foreach (b[i])
b[i]%2!=0;}
c = {a, b};
c.reverse();
Packet p1;
p1 = new();
if (!p1.randomize()) begin
$display ("Randomization Error");
$display ("Value of array A is %p",p1.a);
$display ("Value of array B is %p",p1.b);
$display ("Value of array C is %p",p1.c);
