System verilog interface error
HI,
I am facing an error when i am trying to use interface in the verification environment.
The interface declaration is as follows
interface intf(input wire clock);
logic …
endinterface
ncvlog: *W,NONAIF (/prj/femodel6/FEM_VERIF/indi_work/TARUN/uvm/WB/mem/memory_interface.sv,1|25): Non Ansi Interface port declaration seen - Not official SystemVerilog syntax - [SystemVerilog].
I am unable figure out what is the error in it.Please help me.
With regards,
Tarun
In reply to perumallatarun:
Looks like, this is a warning not an error.
-Vishal
In reply to vishal.savsani:
Thanks for correcting me Vishal. May i know why that Warning is coming ?
Is the using of wire causing a problem in it?
You have not shown enough code.
Please show full code. SystemVerilog has ANSI type of port declaration and Non-ANSI port declaration.
ANSI port declaration is as follows:
output reg [7:0] my_reg); //Defined here as an output reg
Non-ANSI port declaration is as follows:
``` verilog
 my_reg); //Defined here my_reg
output reg [7:0] my_reg; //redefined as an output reg
SystemVerilog allows both types of declarations. The simulator is warning about the Non-ANSI style declaration in your code. Please make sure that you don’t have any Non-ANSI declarations.
