System verilog constraint for transaction
Hi All,
I would like to write a constraint for the following requiement;
Let’s say, there are two random fields;
a) Number of transfers
b) packet length
num_trans:
1 => 1 transfer
4=> 4 transfer
N=> ‘N’ transfers
Packet_length =>
00 => disabled//ignore
01 => 1 packet
10 => 1 packet
11=> 2 packets
//based on $countones. so packet length can be 1 or 2 only.
Scenario_1:
num_trans = 2 and Packet_length = 2, means
2 transfers should take place and in each transfer need to send 2 packets.
Scenario_2:
num_trans = 4 and Packet_length = 1, means
4 transfers should take place and in each transfer need to send 1 packet
code I have tried
module p1;
  class transfer;
    rand bit [1:0] pkt_len;
    rand bit [2:0] num_trans;
    constraint c1{
      $countones(pkt_len)>=1;
    constraint c2{
      foreach(num_trans[i])
        num_trans[i] == num_trans[i]*pkt_len;
      //$displayb("pkt_len %b", pkt_len);
      $display("%0p", obj);
 transfer obj;
    obj = new;
    repeat (4)
    obj.randomize();
output
'{pkt_len:'h1, num_trans:'h7}
'{pkt_len:'h3, num_trans:'h0}
'{pkt_len:'h1, num_trans:'h0}
'{pkt_len:'h1, num_trans:'h6}
The solution is incorrect. Could you please suggest the best approach?
It should looks like transaction class;
For example: 2 transfers 2 packets
T1 => P1, P2
T2=> P2,P2
Thank you,
I don’t understand the results you want. Can you show us exactly the output you expect to see? Even better would be writing directed stimulus that produces an example of the output you expect to see. The we can help you with the constraints.
Does below work for you ?
rand int unsigned num_burst;
rand int unsigned burst_length;
  rand bit [7:0] bursts[][];
  constraint c {
    num_burst inside {[2:4]};
    burst_length inside {[5:6]};
    bursts.size() inside {num_burst};
    foreach (bursts[i]) bursts[i].size() inside {burst_length};
What you want can be achieved by using $countones(pkt_len) on the rhs of constraint c2
