how to solve errors in code
module m(input logic a,b,c,clk,output logic x,y,z);
initial
y=1'b0;
z=1'b0;
always_comb x=a&b;
always_latch y=a|b;
always_ff @(posedge clk)
if(y)
x<=a;
@(posedge clk)
x<=x&b;
final
@(posedge clk)
z <= x|y;
In reply to mudititm:
Hi mudititm. You are driving the x signal from two different always blocks, which is illegal. How do you want the x signal to behave?
There are many errors with your code, but no one knows what the desired behavior should be, so we cannot tell you what you should do.
