I want to do automatic bind connection based on parameter “IF_INST” for the interface with the module present inside generate block, please note than due to some reason, I can not bind interface directly with the “test_bind” module.
module test_bind (input wire [1:0] in_a, output reg [1:0] out_a);
assign out_a = ~in_a;
module top #(parameter INST = 2);
bit [(INST*2)-1:0] temp;
genvar i;
generate
for (i = 0; i < INST; i++) begin: INST_GEN
test_bind t_b (.in_a(i),.out_a(temp[i*2 +: 2]));
endgenerate
interface test_bind_if #(parameter IF_INST = 1) (input logic [(IF_INST*2)-1:0] if_out_a, input logic [(IF_INST*2)-1:0] if_in_a);
$monitor("%m: if_out_a: %b, if_in_a: %b",if_out_a,if_in_a);
endinterface
bind top test_bind_if #(.IF_INST(INST)) bind_mod_if_inst (.if_out_a({INST_GEN[1].t_b.out_a,INST_GEN[0].t_b.out_a}),.if_in_a({INST_GEN[1].t_b.in_a,INST_GEN[0].t_b.in_a}));
