System verilog assertion to check that signal 'a' takes a value only when it has taken some other particular value before
Hi Ben,
I think you didn’t get my request correctly.
I will elaborate by giving an example :
signal = {0,1,3,8,9,2,…}
Now, I want to check that if this signal takes the value of 2, then, sometime before(no fixed time, so “0:$”) it has had the value of 1 as well.
In your previous answer it isn’t clear to me as to how do you store the value of the signal (in this case 1) without using an ‘if condition’ ?
Just on the side-lines, I used a checker to solve the problem :
bit valid_signal = 'b0;
always @(*) begin
if (signal == 'd1)
valid_signal = 'b1;
  if (signal == 'd2)
        ASSERT_RXOVER_MSG_AFTER_START_MSG: assert (valid_signal  == 'b1);
This works fine, but still I would like to know the alternative in SVA.
Thanks a lot!
