Syntax error
I am very new to System Verilog and I am having trouble with understanding some syntax errors. May i know why I am getting this error?
Error-[SE] Syntax error
  "testbench.sv", 58: token is 'endmodule'
1 error
The code:
input    logic          clk,
input    logic          rst_n,
input    logic          clk1,
input    logic          rst1_n,
output   logic          clkout,
output   logic          rstout,
output   logic          interrupt
bind sys_top sys_avmm(
.clk                   (uif_cru.clk[0]),            // <<example>>
.rst_n                 (uif_cru.rst_n[0]),          // <<example>>
.clk1                  (uif_cru.clk[1]),            // <<example>>
.rst1_n                (uif_cru.rst_n[1]),          // <<example>>
.clkout                (uif_cru.clk_mon[2]),        // <<example>>
.rstout                (uif_cru.rst_mon_n[2]),      // <<example>>
.interrupt             (interrupt)                  // <<example>>
module top_tb();
Hope I can get help on this. Thank you.
In reply to ridercom:
Your bind statement does not look correct. It should look like
bind target_name source_name inst_name(
Your code only has two names.
