I tried to compile the below code in vcs 2011.03-SP1.
`include “uvm_pkg.sv”
class wb_packet extends uvm_sequence_item;
rand logic [3:0] address1;
rand logic [31:0] data1;
rand bit [1:0] cntrl;
rand bit rx_negedge1;
rand bit wait_en;
function new(string name = “wb_packet”);
`uvm_object_utils(wb_packet)
endclass : wb_packet
I get the compilation error as below
Error-[SE] Syntax error
“…/testbench/wb_packet.sv”, 5: token is ‘uvm_sequence_item’
I hope the base class library is not compiled.
Can you please help me to solve this error?
My VCS run command is as below
vcs +incdir+$UVM_HOME +incdir+$UVM_HOME/src +incdir+$UVM_HOME/src/dpi -o ./top_verilog -full64 +vcs+lic+wait +v2k -sverilog -I +cli+4 -ucli -M -f sim.fl -l compile.log
