Hi, can anyone help me in dubugging in a syntax error.
syntax error, unexpected IDENTIFIER.
I am getting this error in every component as I have already included the uvm pkg.
Are you saying you have 11 files? The first file is what you originally posted that `includes the 10 other files and is the only file on compilation command line? The “apb_seq_item.sv” file compiles without error?
Yes there are 11 files,
I have compiled every component. Below is the transcript
project open {C:/Users/AIR-NBH-1/Desktop/APB 3/APB 3}
Loading project APB 3
Compile of apb_agent.sv failed with 2 errors.
Compile of apb_drv.sv failed with 2 errors.
Compile of apb_env.sv failed with 2 errors.
Compile of apb_intf.sv was successful.
Compile of apb_mon.sv failed with 2 errors.
Compile of apb_scb.sv failed with 2 errors.
Compile of apb_seq.sv failed with 2 errors.
Compile of apb_seq_item.sv failed with 2 errors.
Compile of apb_sqr.sv failed with 2 errors.
Compile of apb_test.sv failed with 2 errors.
Compile of design.sv was successful.
Compile of testbench.sv was successful with warnings.
12 compiles, 9 failed with 18 errors.
The error is same as I have sent you in earlier response.
apb_seq_item alsoe failed with the same error.
Below is my code. include "uvm_macros.svh" import uvm_pkg::*; include “apb_intf.sv” include "apb_seq_item.sv" include “apb_seq.sv” include "apb_sqr.sv" include “apb_drv.sv”
include "apb_mon.sv" include “apb_agent.sv” include "apb_scb.sv" include “apb_env.sv”
`include “apb_test.sv”
pif.pclk <= 0;
always #10 pif.pclk <= ~pif.pclk;
uvm_config_db#(virtual apb_if)::set(null, “*”, “intf”, pif);
run_test(“apb_test”);
for the above code there is no error but warnings are there
vlog -work work -vopt -sv -stats=none {C:/Users/AIR-NBH-1/Desktop/APB 3/testbench.sv}
QuestaSim-64 vlog 10.7c Compiler 2018.08 Aug 18 2018
** Note: (vlog-2286) C:/Users/AIR-NBH-1/Desktop/APB 3/testbench.sv(1): Using implicit +incdir+C:/questasim64_10.7c/uvm-1.1d/…/verilog_src/uvm-1.1d/src from import uvm_pkg
** Warning: ** while parsing file included at C:/Users/AIR-NBH-1/Desktop/APB 3/testbench.sv(11)
** at apb_scb.sv(35): (vlog-2269) Unterminated string literal continues onto next line 35.
** while parsing macro expansion: ‘uvm_info’ starting at apb_scb.sv(35)
** at apb_scb.sv(35): (vlog-2643) Unterminated string literal continues onto next line.
** at apb_scb.sv(52): (vlog-2269) Unterminated string literal continues onto next line 52.
** while parsing macro expansion: ‘uvm_info’ starting at apb_scb.sv(52)
** at apb_scb.sv(52): (vlog-2643) Unterminated string literal continues onto next line.
** at apb_scb.sv(55): (vlog-2269) Unterminated string literal continues onto next line 55.
** while parsing macro expansion: ‘uvm_info’ starting at apb_scb.sv(55)
** at apb_scb.sv(55): (vlog-2643) Unterminated string literal continues onto next line.
– Compiling package testbench_sv_unit
– Importing package mtiUvm.uvm_pkg (uvm-1.1d Built-in)
** Warning: apb_seq.sv(16): (vlog-2240) Treating stand-alone use of function ‘randomize’ as an implicit VOID cast.
** Warning: apb_seq.sv(39): (vlog-2240) Treating stand-alone use of function ‘randomize’ as an implicit VOID cast.
** Warning: apb_seq.sv(62): (vlog-2240) Treating stand-alone use of function ‘randomize’ as an implicit VOID cast.
** Warning: apb_seq.sv(67): (vlog-2240) Treating stand-alone use of function ‘randomize’ as an implicit VOID cast.
– Compiling interface apb_if
– Compiling module tb
