`uvm_analysis_imp_decl(_vip_rx)
I declare imp like this in scorebaord:
uvm_analysis_imp_vip_rx #(ethernet_transaction, scoreboard) exp_vip_rx;
but I see this syntax error:
token is ‘#’
So the error is pointed at ‘#’
analysis port and imp are connected in my env (agent is also instatiated in env).
But there is some syntaz error which I am unable to debug, can you please tell how can I debug it or what is the syntax error?
I have looked above this specific line and below this line to see if any syntax error above/below is causing this, but no, apparently everything else is fine.
