I need to write a property to check the divisor of a fast clock. I’ve tried the following options:
property clk_frequency_P(logic pll_clk, logic destination_clk, logic clk_en, logic reset, int divisor);
@(posedge destination_clk) disable iff (~reset)
(clk_en == 1) |-> $stable(destination_clk) ##(divisor/2) @(posedge pll_clk);
(clk_en == 1) |-> $stable(destination_clk) @(posedge pll_clk) ##(divisor/2);
However, I encountered compilation errors with both options:
xmvlog: *E,ILLPRI: illegal expression primary [4.2(IEEE)].
xmvlog: *E,SVAPNS: Property declaration must end with "endproperty".
How can I use a different clock for the stable cycles? I know there are other ways to check that the divided clock generates the correct frequency, such as using $period, but I want to verify it by counting the fast clock cycles.
does not make sense.
@(posedge pll_clk) expression_or_signal_or_a_sequence_must_be_here.
You have nothing atger the @(posedge pll_clk.
I suggest that you use support logic with immediate assertions.
for counts, you could use a task with 2 forked threads and count then number of clocks. something like (untested)
task automatic t_clk;
int v1, v2;
bit done1, done2;
repeat(20) @(posedge clk1) v1++;
done1=1;
repeat(20) @(posedge clk2) v1++;
done2=1;
join_none
wait(done1 && done2);
am12: assert(v1/v2 == 2); // v1 is 2x v2
initial @(posedge clk) begin
fork t_clk();
join_none;
That’s not what I asked.
I asked how can I make the stable works by the pll_clk, instead of the destination clock.
I just want to verify that the destination_clk is stable for N pll_clk cycles
bit v;
divisor==2 && (clk_en == 1) |=>
@(pll_clk) ((1, v=destination_clk) ##1 destination_clk==v)[*2];
bit v;
divisor==4 && (clk_en == 1) |=>
@(pll_clk) ((1, v=destination_clk) ##1 destination_clk==v)[*4];
// You can use the generate for more divisor values.
// Untested, but I see it this way:
ppl_clk 1 0 1 0 1 0 1 0
dest_clk 0 1 1 0 0 1 1 0 0 // divisor==2
dest_clk 0 1 1 1 1 0 0 0 0 1 1 1 1 // divisor==4
