Hi
For some reasons I need to evaluate sequence from the end to the start.
if “target” changed from '0 to '1, so:
a) “clear” was '0 in the previous clock cycle.
b) “enable” was '1 in the previous clock cycle.
c) “rstn_a” must be '1 all over the flow.
d) when “d_in” changed from '0 to '1, “rstn_b” have to be '1, until the clock cycle where “enable” should be '1 (one cycle before “target” changed to '1 from '0).
Again, the assert start only after I know that target rise.
thanks
can I use $past for unknown amount of time?
section “d” above require rely on the other parts - the number of clocks is unknown, I just know that now target rise, so clock before enable were '1, and all the time before the enable condition, since d_in came, rstn_b must be '1…
a) “clear” was '0 in the previous clock cycles (over the flow)
sequence s_clear;
@(posedge clk) clear[->1] intersect rstn_a[*1:$];
endsequence
assert property(@(posedge clk) $rose(clear) |->
s_clear.triggered && $past(enb));
[You] d) when “d_in” changed from '0 to '1, “rstn_b” have to be '1,
[Ben] ??
sequence s_enb;
@(posedge clk) rstn_b[*1:$] interesect enb[->1] ##1 1;
endsequence
assert property(@(posedge clk) $rose(din) |-> s_enb.triggered);
Ben Cohen Ben@systemverilog.us
Hi Ben
Thanks for your reply.
I can’t see where, in your code, is there a reference to “target”, and to the fact that the entire check is performed on the time prior to its increase.
Thanks again
