My Sequence is asserting every “posedge side_clk and iff oopi_sb_mnpput”.I need the sequence should assert once at oopi_sb_mpayload[7:0]==8’h40 and check the transition until oopi_sb_mpayload[7:0]==8’h00 as per the assertion coded above.
Right now, As you can see in the waveform picture,assertion triggers every time when posedge side_clk iff oopi_sb_mnpput, and oopi_sb_mpayload[7:0] for other values.
I would like to know how to filter triggering the sequence.
What you have is a sequence; I assume that you are talking about an assertion of that sequence.
The link to the image is incorrect. What I think you want though is something like:
