It would be helpful if you could create a small test case that demonstrates the problem.
Also, when you say toggle, do you really mean asserted/rose? And is it a requirement that a must remain asserted for 10 cycles? can there be overlapping windows?
Yes we want only a single pulse ( posedege + negedge ) of b within the window.
Yes a has to be continuously 1 ie, a[*10]
Test Case Summary
Case 1: Single Pulse (Expected Pass)
In this scenario, signal b rises and falls exactly once while a remains asserted for a continuous window.
a:0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1
b:0 0 0 0 0 1 1 1 1 1 1 1 0 0 0 0
Case 2: Double Pulse (Expected Fail)
In this scenario, signal b rises and falls twice while a is asserted. This should trigger a failure.
b:0 0 0 0 0 1 1 0 0 1 1 1 0 0 0 0
Core Constraint
We should only have 1 pulse of ‘b’ within the window of 10 (or n cycles) of ‘a’ being 1
The within construct is not strict for multiple matches and is passing.
1 pulse → within → passing
2 pulse → within → again passing since within is not strict 1 match but we want ONLY 1 match.
** Also first_match wont work since the 2nd pulse is also identical and it eventually becomes the first_match for the final matching logic.
***Note ***
Refer to the property throughout_ab
Also i made it *15 cycles in the EDA playground to match the 2 pulses of b.
Let me know if its still not clear I can add more info.
sequence cycles(n);
##1 1[*n]; // cycle window
endsequence
sequence one_pulse(sig);
$rose(sig) ##0 $fell(sig)[->1];
endsequence
property within_ab;
@(posedge clk)
$rose(a) |->
// a stays high
a throughout cycles(10)
and
// one pulse of b in the window
one_pulse(b) within cycles(10)
and
// prevent another rise of b after the first pulse
not (one_pulse(b) ##0 b[->1]) within cycles(10)
Oh okay yeah!!! ideally this one I did not keep the ONE CLOCK strict requirement.
It has to be only one rising edge + falling edge. I thought once we design that we can tweak it if ever we want for single CC. But GOOD ONE ! that you pointed lets ponder about it
The below one also works @(posedge clk) $rose(a) |-> ($rose(b)[->1] ##1 $fell(b) ##0 !b[*1:$]) intersect (a[*15])
But I like your solution its much more cleaner @(posedge clk) $rose(a) |-> (b[->1] ##1 !b[*1:$]) intersect a[*15];
