In reply to ADITYA ABHISHEK:
Of the 2 solutions, I prefer the use of tasks instead of SVA for this particular problem.
(code could be made more compact)
In SVA, you need to counter, the first_match(), and the intersect.
code http://systemverilog.us/vf/read_wr2.sv
bit clk, we, wr, rd;
bit[3:0] depth =2;
event s, e, p; // for debug
string tID="RD_WR";
/* There are below Input signals- WE,WR,RD.
and output signal - USED
When WE = 1, WR = 1, RD = 0. on first clock cycle,
then till `depth-1 cycle , WE=0,WR=0,RD=1,
then finally on N cycle, WE should be 1.
But if in between WR = 0 and RD =1 then Depth should increase by 1 for every such clock. */
task automatic t_write();
automatic bit rtn;
if($rose(we && wr && !rd)) begin : rose_we // attempt succeeds
-> s; // start
repeat(depth-1'b1) begin : DEPTH_REPEAT
@(posedge clk);
a_depth: assert(depth == $past(depth) - 1'b1) else rtn=1'b1;
a_we0_wr0_rd1: assert(we==0 && wr==0 && rd==1'b1) else rtn=1'b1;
if(we==1'b1 || wr==1'b1 || rd==1'b0 || rtn==1'b1) begin
-> e; // error
`uvm_info(tID,$sformatf("%m : error in we %b or wr %b or rd %b or depth %b", we, wr, rd, depth), UVM_LOW);
return;
end : DEPTH_REPEAT
@(posedge clk); // last cycle
a_we1: assert(we==1'b1) else rtn=1'b1;
rtn=1'b1;
`uvm_info(tID,$sformatf("%m : error in depth %b", depth), UVM_LOW);
if(we==1'b1 && depth == $past(depth) - 1'b1 && rtn==1'b0) -> p; // pass
else begin
`uvm_info(tID,$sformatf("%m : error in depth %b or we %b", depth, we), UVM_LOW);
-> e;
end : rose_we
else return; // not really needed statement
property p_write;
bit[3:0] w;
($rose(we && wr && !rd), w=depth) |->
(first_match((##1 (we==0 && wr==0 && rd==1'b1), w=w-1) [*1:$] ##0 w==1)
intersect ((##1 depth== $past(depth) -1'b1) [*1:$]))
##1 (we==1'b1);
ap_write: assert property(p_write);
initial forever #10 clk=!clk;
always @(posedge clk) t_write();
repeat(200) begin
@(posedge clk); #2;
if (!randomize(we, wr, rd, depth) with
{ we dist {1'b1:=1, 1'b0:=1};
wr dist {1'b1:=1, 1'b0:=2};
rd dist {1'b1:=2, 1'b0:=1};
depth dist {4'b0001:=1, 4'b0010:=1, 4'b0011};
$stop;
UVM_INFO read_wr.sv(25) @ 730: reporter [RD_WR] top.t_write.rose_we.DEPTH_REPEAT : error in we 1 or wr 0 or rd 1 or depth 0010
# ** Error: Assertion error.
# Time: 730 ns Started: 710 ns Scope: top.ap_write File: read_wr.sv Line: 52 Expr: we==0
# Local vars : w = 2
# UVM_INFO read_wr.sv(34) @ 810: reporter [RD_WR] top.t_write.rose_we.a_depth : error in depth 0010
# UVM_INFO read_wr.sv(38) @ 810: reporter [RD_WR] top.t_write.rose_we : error in depth 0010 or we 1
# Time: 810 ns Started: 790 ns Scope: top.ap_write File: read_wr.sv Line: 52 Expr: we==0
# Local vars : w = 1
# UVM_INFO read_wr.sv(25) @ 1250: reporter [RD_WR] top.t_write.rose_we.DEPTH_REPEAT : error in we 0 or wr 0 or rd 0 or depth 0011
# Time: 1250 ns Started: 1230 ns Scope: top.ap_write File: read_wr.sv Line: 52 Expr: rd
# Local vars : w = 3
# UVM_INFO read_wr.sv(25) @ 1730: reporter [RD_WR] top.t_write.rose_we.DEPTH_REPEAT : error in we 1 or wr 0 or rd 0 or depth 0001
# Time: 1730 ns Started: 1710 ns Scope: top.ap_write File: read_wr.sv Line: 52 Expr: we==0
