In reply to rkg_:
Look at the the syntax of a sequence; one of them is
sequence_expr ::=
... | ( sequence_expr {, sequence_match_item} ) [ sequence_abbrev ]
// example
// At end of subsequence a ##1 b, j=0.
// Starting from next cycle c must remain 1 for as
// many cycles as defined by the value of the
// argument cy (j is incremented until j==cy).
property P(int cy);
int j=0; // initialization optional, legal in SV’09
(a ##1 b, j=0)|->
##1 (c, j+= 1) [*0:$] ##1 j==cy;
endproperty : P // See below for more examples
// corrected using 1'b1 as the sequence_expr
property out_bits_incr_prpty;
bit[7:0] v;
// @(posedge monclk_output) disable iff(!i_en_fll)
@(posedge sampled_monclk) disable iff (!i_en_fll)
##1 1 |-> if (monclk_count < i_count)
(1'b1, v=incr(o_prog_out_fll, sar_mask ,monclk_count, i_count)) ##0 v
(1'b1, v=decr(o_prog_out_fll, sar_mask ,monclk_count, i_count)) ##0 v ;
