SVA: an alternative to the "always"
Question: Once enable goes high in the next cycle, one pulse on signal “a” (1 cycle)
should be generated and from there it should be generated for every three clock cycles.
Got this request and it looked like a perfect adaptation for the use of the always property,
something like the following, but that did not work as with edaplayground tools do not seem to support
that property correctly.
ap_a10: assert property(
    @(posedge clk) $rose(enb) |-> always[1:100] (a |-> ##1 !a[*3] ##1 a))
      notify(1); else notify(0); */
So I took a different approach where with support logic I issued a “go” signal when enb completed the pulse.
// The enable and the go and the "a==1" after the enb
    $dumpfile("dump.vcd"); $dumpvars;
    repeat(3) @(posedge clk);  // a start delay
      enb <= 1;
      fork t_a10(); join_none  // the test vector generation task
      @(posedge clk) enb <= 0; go <=1; @(posedge clk);
      am_0a: assert property (@(posedge clk) a==1)
        $display("%t a==1 after enb goes to 0", $realtime); else
        $display("%t a==0 after enb goes to 0", $realtime);
    repeat(50) @(posedge(clk));
    $finish;
The assertion
  ap_a10b: assert property(
    disable iff(go==0)
    @(posedge clk) a |-> ##1 !a[*3] ##1 a)
Code and results
  /* Once enable goes high in the next cycle, one pulse on signal "a" (1 cycle)
     should be generated and from there it should be generated for every ten clock cycles. */
  bit clk, enb, a, go, reset_n;
  int pass, fail;
  initial forever #1 clk = !clk;
  let T=3;
  function void notify(bit p);
    if(p) begin pass=pass+1; $display("%t ap_a10 PASS", $realtime); end
      else begin fail=fail+1; $display("%t ap_a10 FAIL", $realtime); end
  /* ap_a10: assert property(
    disable iff(go==0)
  task automatic t_a10(); // test vector generation
    repeat(4) begin // good condition
      @(posedge clk) a<=1;
      repeat(T) @(posedge clk) a<=0;
    repeat(4) begin // error condition
      repeat(T-1) @(posedge clk) a<=0;
      enb <= 1;
    $finish;
run -all
#                    9 a==1 after enb goes to 0
#                   17 ap_a10 PASS
#                   25 ap_a10 PASS
#                   33 ap_a10 PASS
#                   41 ap_a10 PASS
#                   47 ap_a10 FAIL
#                   53 ap_a10 FAIL
#                   59 ap_a10 FAIL
#                   67 ap_a10 FAIL
Ben@systemverilog.us
or Cohen_Links_to_papers_books - Google Docs
