SV Regex Bracket Match
I am trying to create a simple pattern match using regex in SV. I see that its not able to match it although the regex looks right. I tested it out in
  string s = "test[0]";
    if(s.match(".*[\d].*") ) $display("MATCH");
    else $display("NOMATCH");
Other things that should ideally work but its still no match:
The only thing that I see working is:
".*[0].*"
What if I want to match any number inside the “”?
In reply to ritz91:
    if(s.match(".*[\\d].*") ) $display("MATCH");
In reply to rag123:
Thank you! Now I think it matches everything
string s = “test[0123]”;
It should be “\d+” may be to match “0123”.
