SV Functional Coverage
How to write a bins for 32 bit variable in system verilog functional coverage?
For e.g we have bit [31:0] data; if we write explicit bins for that then it will have 2**32 possible values.
Can anyone explain this?
Creation of bins depends on the specification given and the stimulus you gonna provide on the 32 bit data line as per the SPEC.
For example,
data_cp : coverpoint data {
                           bins low = {[0 : 1023]};
                           bins low_1 = {[1024 : 2047]};
                           bins high = {[2**32 - 1024 : 2**32 - 1]};
Thank you for answer.
I know this way and I also told to interviewer same answer but he asked me is there any other way to write it.
I believe the option auto_bin_max can be used
option.auto_bin_max=32;
you can try to use wildcard bins. something like this.
wildcard bins bin_min = { 4’b11?? };
wildcard bins bin_med = { 4’b0??? };
wildcard bins bin_max = { 4’b1??? };
Thank You for answer.
But if we do calculation of this it means 2^32 = 4294967296
i.e. 4294967296 / 32 = 134217728
So each bin will be created like this…
[0: 134217727]
[134217727: 268435455]…so on
Total 32 bins will be created.
Do we do like this in real time also?
  • can you please elaborate this for 32 bit variable?
