I have a follow-up question . I notice that following code in procedural block ( like initial block ) works fine and give same result ::
bit [3:0] b [$] = '{ 1 , 6 , 2 , 1 , 9 , 1 , 2 , 10 , 15 } ;
int b1 ;
b1 = b.sum() with ( ( item == 1 ) ? item : 0 ) ;
$display(" b is %0p",b);
$display(" Result of b.sum() with ( ( item == 1 ) ? item : 0 ) is %0d ",b.sum() with ( ( item == 1 ) ? item : 0 ));
$display(" Result of b.sum() with ( ( item == 1 ) ? 1 : 0 ) is %0d ",b.sum() with ( ( item == 1 ) ? 1 : 0 ));
$display(" Result of b.sum() with ( ( item == 1 ) ? ( item == 1 ) : 0 ) is %0d ",b.sum() with ( ( item == 1 ) ? ( item == 1) : 0 ));
Whereas if I try it in a Constraint all 3 of the variation fails ::
// TYPE 1
a.sum() with ((item == 1) ? item == 1 : 0 ) == 10 ;
a.sum() with ((item == 2) ? item == 2 : 0 ) == 5 ;
a.sum() with ((item == 3) ? item == 3 : 0 ) == 5 ;
// TYPE 2
a.sum() with ((item == 1) ? item : 0 ) == 10 ;
a.sum() with ((item == 2) ? item : 0 ) == 5 ;
a.sum() with ((item == 3) ? item : 0 ) == 5 ;
// TYPE 3
a.sum() with ((item == 1) ? 1 : 0 ) == 10 ;
a.sum() with ((item == 2) ? 2 : 0 ) == 5 ;
a.sum() with ((item == 3) ? 3 : 0 ) == 5 ;
