I want to write a SV code where from a given array, I want to generate another array with random numbers from the 1st array such that sum of those numbers(2nd array) is always 15. Also, if a value from one index is chosen once, it cannot be chosen again from array1. Here’s the code:
class try;
  int in []='{2,2,3,5,8,10};
  rand bit[5:0] en;
  rand int unsigned sel[];
  constraint c1{sel.sum==15;}
  constraint c4{sel.size()==$countones(en);}
  constraint c3{en>0;}
  constraint c2{foreach(in[i]){
    if(en[i]==1){
      sel[sel.sum() with (int'(item>0))]==in[i];
module test;
  try t1;
  initial begin;
    t1=new();
    t1.randomize();
    $display("value of en_port =%b and selected ports =%0p",t1.en,t1.sel);
The issue is that my randomization is failing here. Can you please help me with how to correctly code it?
