SV: "atohex" fails for strings representing more than 32 bits, if bits set above that bit
Runninq Questa 10.7c
See System Verilog code below. This runs “atohex” three times to convert three different strings of nine hex characters, each to a 36-bit vector (35:0).
The problem is that the most significant hex digit of the output bit vector (representing bits 35:32) is incorrect, if it has bits that should be nonzero.
 string    hex;
      bit[35:0] num;
      hex = "012345678";
      $display ("hex = %s",hex);
      num = hex.atohex();
      $display ("num = %x",num);
      hex = "812345678";
      num = hex.atohex();
      hex = "5FFFFFFFF";
      num = hex.atohex();
Here is the response from simulation: Note how the most significant hex digit (representing bits 35:32) is incorrect if the input hex digit has a bit set in the upper nibble. The first example has none of the bits set in the upper nibble, so it works. The last two examples fail since they have bits set in the upper nibble.
# hex = 012345678
  # num = 012345678
  # hex = 812345678
  # num = 012345678
  # hex = 5FFFFFFFF
  # num = fffffffff
Can anyone tell my why “atohex” is behaving this way? atohex is supposed to work for strings longer than 8 characters (32 bits), correct?
Thanks for your help!
Matt
In reply to mtgavin:
The return type of
atohex()
is integer, which is a 32-bit signed type.
If you need to convert values larger than 32-bits, use $sscanf as the LRM says.
status = $sscanf(hex, "%h", num);
It works. Thanks Dave!
I have a string the should convert to hex with 128 bits.
wrote
$sscanf(str, "%h", hex);
but it not working.
can help please?
thanks
It would strongly help to show a complete reproducible example
and explain what you mean by “not working”.
This works for me
  string str = "FEDCBA98_76543210_01234567_89ABCDEF";
  bit [127:0] hex;
    $displayh(hex);
