SV Assertions using $past()
I’ve this question. Please advise SV and SV experts.
I wanted to ask you a conceptual question on SVA that I’m facing.
The question is to write SVA for T FF with no reset or preset.
My approach:
property toggle_cond;
 @(posedge clk) t |=> q == ~($past(q, 1));
enproperty
property no_change;
 @(posedge clk)  (t==0) |=> q == $past(q, 1));
enproperty
NC : assert property(no_change);
NC1: assert property(toggle_cond);
I find my solution is correct, but when I check on Gemini/ChatGPT, it is saying that its incorrect. This is because Don’t use |=> and $past() in the same expression for simple flip-flop logic. It makes the code harder to debug.
According to my understanding of SVA fundamentals,
When t is LOW (ANTECEDENT is TRUE), then in the next clock cycle, check the CONSEQUENT where Q_next is complement of the Q_current. Isn’t this how we test T-FF functionality? Please correct me if I’m mistaken and there might be gap in my knowledge.
As per GPT it is suggesting I should use, overlapping operator. But, will it change the very definition of T-FF?
Please advise and correct me.
Thank you
I don’t see any issue with your code.
The only addition that I would do is to check that current and previous values aren’t X / Z
Note that the 2nd argument to $past has default value of 1.
So $past(q,1) and $past(q) are essentially the same
ChatGPT isn’t giving you absolutely correct advice. A |=> B is functionally equivalent to A |-> ##1 B. They’re not functionally equivalent without the 1 cycle delay.
The widely accepted recommendation is to use only the overlapping implication |-> to avoid any confusion.
