I have two groups of items A and B such that the size of group A is greater or equal to the size of group B.
How can I create a mapping array that maps items from group A to items in group B, such that all items in group B are mapped.
for instance, if A={0,1,2,3,4,5} and B={0,1,2} so
'{0,1,1,0,2,1} is a valid mapping
but '{0,1,1,0,0,1} is not a valid mapping since ‘2’ of group B is not mapped
Your question is missing some details. Are there three groups of items: A, B, and the mapping array? Or is A the mapping array? How do the initial values 0-5 of group A work in the mapping algorithm?
From the example you gave, it appears that every value in group B must appear at least once in the mapping array,
Groups A and B are given, I want to create a random array which it’s indices represent elements from group A and the values represents element from group B - in that way I map each index to value.
In mathematical form, I want to randomize a function f:A->B, so that for every value b in group B there is a value a in group A such that f(a)=b.
Maybe the structure of array is confusing, here is how I thought to do it using an associative array:
int A[6] = '{0,1,2,3,4,5};
int B[3] = '{0,1,2};
rand int mapping_array[int];
constraint surjective_mapping_c {
foreach (A[i]) {
mapping_array[A[i]] inside {B};
but I’m missing the constraint to ensure all B’s values are used in the mapping array
Could the mapping_array have more elements than the number in A? (i.e. could there be a mapping_array[7]) If so, are there any constraints on those element’s values?
Are the values in A and B guaranteed to be unique?
Realize that a constraint cannot construct elements of an associative array. You have to allocate elements before calling randomize.
Now there is enough information to suggest a solution.
class example;
int A[6] = '{10,1,2,3,4,5};
function void pre_randomize();
// construct associative array before randomization
mapping_array = '{};
foreach (A[i]) mapping_array[A[i]] = 0;
// each element of m_a must be in B
foreach (mapping_array[i])
mapping_array[i] inside {B};
//B’s values are used at least once in the mapping array
foreach (B[i])
mapping_array.or() with (item == B[i]);
example h = new;
initial repeat(5) begin
assert( h.randomize() );
$display("%p",h.mapping_array);
Cannot suggest a better structure to implement without knowing how you plan to use the results.
