DUT computes the histogram of an image composed of 8x8 pixels. Each pixel can be either red, green, blue or defective. Valid images must comply with the following requirements:
a. No more than 25% defective pixels.
b. No sub-matrix of 3X3 size should have all defective pixels.
Examples (D is defective, ‘.’ stands for any of red/green/blue)
Bad (violates condition b)
DDD…
DDD…
DDD…
Good
DD.D…
DDD…
DDD…
BAD
.DDD…
.DDD…
.DDD…
I am able to solve first part through the below code.
module tb;
typedef enum bit [1:0] {red, blue, green,defective} pixel_t;
class matrix;
rand pixel_t a[8][8];
constraint c2{
a.sum(item1) with (item1.sum(item2) with (int'(item2==defective))) < 16;
Endmodule
How do I solve the 2nd part?
module tb;
typedef enum bit [1:0] {red, blu, gre,DEF} pixel_t;
class matrix;
constraint c1{ // easier to read brute force approach
foreach(a[i,j])
i inside {[1:6]} && j inside {[1:6]} ->
a[i-1][j-1]==DEF &&
a[i-1][j ]==DEF &&
a[i-1][j+1]==DEF &&
a[i ][j-1]==DEF &&
a[i ][j ]==DEF &&
a[i ][j+1]==DEF &&
a[i+1][j-1]==DEF &&
a[i+1][j ]==DEF &&
a[i+1][j+1]==DEF
constraint c1_alternative{ // harder to read, but more programmable
foreach(a[i,j])
!a.and(R) with (R.index inside {[i-1:i+1]} ?
R.and(C) with (C.index inside {[j-1:j+1]} ? C==DEF : '1)
:'1);
constraint c2{
a.sum(item1) with (item1.sum(item2) with (int'(item2==DEF))) <= 16;
matrix m = new;
initial repeat(5) begin
assert(m.randomize());
foreach (m.a[i]) $display("%p", m.a[i]);
$display;
Do you mind explaining how this above iteration works?
Also, I tried using the “dist” but I see all ONLY defective being picked when I use the below constraint
constraint c2 {foreach (a[i,j]){
a[i][j] dist{{RED, GREEN, BLUE} :/ 75, DEF:/ 25};
Any feedback why this will not work?
Thanks much!
Your syntax is concatenating {RED, GREEN, BLUE}.
You want a range, or list individually
a[i][j] dist{[red:gre] :/ 75, DEF:/ 25};
