Hi dave,
Happy to hear fom you again.
I quote my SV code here.
class packet;
rand byte a,b,c,d,e,f,g;
//Constraining values from 1 to7
constraint value {a>0; a<8;
b>0; b<8;
c>0; c<8;
d>0; d<8;
e>0; e<8;
f>0; f<8;
g>0; g<8;
//No one shares same floor
constraint unique_value { unique {a,b,c,d,e,f,g};}
//E does not live on an even numbered floor
constraint E { e%2 !=0;}
//G does not live on the top most floor
constraint G { g != 7;}
//Only one person lives between E and G
constraint E_G { e-g == 2 || g-e == 2;}
//A does not live on even numbered floor and does not live below F
constraint A { a%2 !=0; a > f; }
//D does not live immediately above or immediately below G
constraint D_G { d-g != 1 || g-d != 1;}
// There two floors between D and E
constraint D_E { e-d == 3 || d-e == 3;}
// Both B and C live on even-numbered floor.
constraint B { b%2 == 0;}
constraint C { c%2 ==0;}
// F lives on floor number 5
constraint F { f == 5;}
//G and C live in between the two floors.
constraint G_C { g-c == 1 || c-g == 1;}
function void print();
$strobe("A = %0d", a);
$strobe("B = %0d", b);
$strobe("C = %0d", c);
$strobe("D = %0d", d);
$strobe("E = %0d", e);
$strobe("F = %0d", f);
$strobe("G = %0d\n", g);
endfunction : print
module tb;
packet obj;
repeat(1) begin
obj= new();
void'(obj.randomize());
obj.print();
$finish();
endmodule : tb
Since your $finish is a statement inside an initial block of a module, it’s the executed in the active region. But regardless, the output from $strobe gets schedules in the last region --postponed.
