String to hierarchical path
Anyone know a way to covert a string into a hierarchical path name?
I’d like to use the LL_DRIVER_BFM string to form the path dut_top.(LL_DRIVER_BFM)
const string LL_DRIVER_BFM   = "SysLnp_LL_Rx_drv_bfm";
uvm_config_db #( virtual LL_driver_bfm  )::set( null , "VIRTUAL_INTERFACES", LL_DRIVER_BFM  , dut_top.LL_DRIVER_BFM ) ;
Brian
In reply to bmorris:
Of course no sooner than I have posted the question, I see a post from Dave from 2011 saying that
hierarchical path names have to be statically typed, SV cannot convert a string name to a path name.
Has anything changed since then, perhaps?
Nope, you’re going to have to write them all out explicitly. I’d also do the config DB set from the top.
In reply to Tudor Timi:
Well not a big concern. It’s only a single place in the top that’s affected.
I’ve got a dual-top, dut_top (instantiations) and tb_top (db access etc). I picked that up from mentor’s cookbook, just for separating complexity.
Don’t we have a way yet to do this in SV without much complication ? If there was, it would be very helpful for me, as I would otherwise have to statically type it down for 5105 times as it is a multidimensional array in my case!
