Stream to struct
Hi All,
I am new to system verilog. I followed this tutorial[1] to create my own message deserializer.
The stream is in little endian byte ordering. The struct is a simple 2 bytes size and 1 byte count.
It is ok if streaming field by field but it doesn’t work if directly stream to struct.
Please check the code[2] and run output[3].
Please kindly advise.
Regards,
Ken
[1] https://www.amiq.com/consulting/2017/06/23/how-to-unpack-data-using-the-systemverilog-streaming-operators/#unpack_an_array_into_the_fields_of_a_structure
[2] code:
module stream;
  typedef struct {
    shortint size; // 2 bytes
    byte count; // 1 bytes
  } packet;
  logic [23:0] data = {23'h1c0001}; // size = 28, count = 1, little endian
  initial
    static packet msg;
    $display("stream field by field:");
    $display("size = %d", {<<8{data[23:8]}});
    $display("count = %d", {<<8{data[7:0]}});
    $display("stream to struct:");
    {>>{msg}} = {<<8{data[23:0]}}; // please advise how to unpack the data to msg struct
    $display("msg.size = %d", msg.size);
    $display("msg.count = %d", msg.count);
[3]
Loading work.stream
run
size = 28 // ok
count = 1 // ok
stream to struct:
msg.size = 256 // not ok. expected : 28
msg.count = 28 // not ok. expected : 1
