Static task and automatic task
class a;
  static int b;
  task c(); // then with static task c()
   b++;
   $display (b) ;
in the above mention code for both static task and task i’m getting same output . what is the different please anyone explain me ?
In reply to rkrajan96:
Please read http://sscce.org/ and then see what is the exact difference between static tasks/functions and automatic tasks/functions ? please explain with a clear example | Verification Academy
Thanks for that explaining .But I cannot able to relate with my example . Why for me output is same would you please explain with that ??
How about explaining why you expect different results.
Here is static class method definition in SystemVerilog LRM. In your example, you won’t see result difference between non-static class method task c() and static class method static task c(). I think you may need to differ the concept between a static method and the task with the static lifetime as well.
  1. Classes
    8.10 Static methods
  • Methods can be declared as static.
  • A static method is subject to all the class scoping and access rules, but behaves like a regular subroutine that can be called outside the class, even with no class instantiation.
  • A static method has no access to non-static members (class properties or methods), but it can directly access static class properties or call static methods of the same class.
  • Access to non-static members or to the special this handle within the body of a static method is illegal and results in a compiler error
  • Static methods cannot be virtual.
A static method static task c() is different from a task with static lifetime task [lifetime] c(). The former refers to the lifetime of the method within the class, while the latter refers to the lifetime of the arguments and variables within the task.
[lifetime] can be static or automatic. The methods Tasks defined within a class are always automatic
In reply to Lina.Lin:
Thanks for bro . I got to know now . Thanks for your valuable response
