Can someone please help me understand the problem with the below code ? As per my understanding static member is independent of the class instance, so this should work.
class packet;
bit [31:0] addr;
static bit [31:0] id;
function void display(bit [31:0] a, bit [31:0] b);
$display("Values are %0d %0d", a, b);
module sro_class;
// Access and modify static member without instance
packet::id = 20;
// Create an instance of the class
packet p;
p = new();
// Use instance to call non-static method
p.display(packet::id, 2);
// Access static member via instance (not recommended but works)
$display("Static id via instance: %0d", p.id);
