I have problem understanding the meaning of a static class handle, which is referred to only once in LRM, section 6.8.
As far as I understand, in the following piece of code which I quote from Chris Spear’s book, ‘me’ is an example of a static class handle:
class svm_component;
class svm_component_registry #(type T=svm_component, string Tname="<unknown>");
typedef svm_component_registry #(T,Tname) this_type;
local static this_type me = get(); // Handle to singleton
static function this_type get();
if (me == null) begin // Is there an instance?
me = new(); // Build the singleton
return me;
Now what is the behavior of ‘me’ handle declared as static? What happens when it is constructed using the get() function? It can be seen that the get() function is called inline with the declaration of ‘me’. Does this mean that an object is automatically constructed at compile time of the class svm_component_registry?
No, you are confusing class variables with class handles. The variable is static, not the handle. All static variables regardless of their type get initialized once at run-time 0, before any initial or always block processes begin.
Thank you Dave, I get it better now, after reading your reply and the article you suggested. So if I understand correctly, in the above example, the class svm_component_registry must be constructed somewhere else in a procedural block, which will cause ‘get()’ function to be called automatically and construct an object for ‘me’, right? I mean, ‘me’ is constructed automatically upon construction of an object of type svm_component_registry. Is that correct?
That is still incorrect. Static class properties, like any other static variables get initialized once at time 0. They do not require the class they are contained in to ever be constructed.
