Static And Automatic Methods
I am observing 2 different outputs for a same piece of code which is called only once, the only difference is that one method is static and other is automatic.
As per my understanding if the method is called only once, then the static or automatic should not have any effect.
Below are the sample codes and output.
Code:
task automatic generateCRC(input bit [31:0] crc_poly, input bit [31:0] crc_seed, input bit [7:0] data_stream[], output [31:0] crc_start_value);
  bit [31:0] crc_temp = crc_seed;
  bit [7:0] data;
  for (int i = 0; i < data_stream.size; i++)  // Byte-Stream
      data = data_stream[i];
      for (int j=0; j < 8; j++) // from LSB to MSB in one byte
          if ((crc_temp[31]) != (data[7])) begin
            crc_temp = (crc_temp << 1) ^ crc_poly;
          else begin
            crc_temp <<= 1;
          data <<= 1;
  crc_start_value = crc_temp;
task generateCRC1(input bit [31:0] crc_poly, input bit [31:0] crc_seed, input bit [7:0] data_stream[], output [31:0] crc_start_value);
  //compute the field values from the control_reg value
  bit [7:0] data;
          else begin
            crc_temp <<= 1;
          data <<= 1;
  bit [31:0] crc;
  bit [31:0] crc1;
  logic [7:0] data[] = {'h87, 'h11, 'h55, 'h99, 'h32};
    generateCRC('hc9d204f5, 'h3, data, crc);
    $display("Automatic task output %0h", crc);
    generateCRC1('hc9d204f5, 'h3, data, crc1);
    $display("Static task output %0h", crc1);
Output:
Automatic task output 83980f08
Static task output c72cbc03
The declaration of crc_temp inside task generateCRC1 is illegal for the very reason you are seeing incorrect results.
