SPI Mode fault feature(MODF) Feature
SPI has one feature for multiple masters when it uses the ss bar signal to detect the collision if the 2 master(or more) are selected as master and driving the ss bar signal zero so how this is done I am not able to understand the process how 1 master already driven the ss bar signal low then another master is trying to drive that signal to zero again then how we are detecting that this feature in spi is called the mode fault feature if any one have implemented this please answer.
Thanks.
In reply to m_v:
In SPI (Serial Peripheral Interface), the mode fault feature is related to the issue of multiple masters trying to communicate on the same bus simultaneously. SPI is designed for communication between a master and one or more slave devices, but it doesn’t inherently prevent multiple masters from trying to control the bus at the same time.
The Slave Select (SS or CS) signal is used to enable communication with a specific slave device in a multi-slave SPI setup. When a master asserts (drives low) the SS signal, it indicates that it wants to communicate with a particular slave. The mode fault detection mechanism helps in identifying scenarios where multiple masters are trying to assert the SS signal simultaneously.
Here’s a high-level explanation of how the mode fault detection might work:
Monitoring SS Signal:
The SPI bus is monitored for the state of the SS signal.
Each master should check the state of the SS signal before initiating communication.
If the SS signal is already low (asserted), it implies that another master is currently communicating with a slave, and the new master should avoid interfering.
Collision Detection:
If a master detects that the SS signal is low when it tries to assert it, it implies a collision.
The collision detection mechanism can trigger a mode fault condition.
Mode Fault Handling:
When a mode fault is detected, the master can take specific actions, such as:
Abort the ongoing communication attempt.
Retry communication after a delay.
Report an error to higher-level software or firmware.
Implement a bus arbitration mechanism to resolve conflicts.
Arbitration (Optional):
In some systems, a more sophisticated arbitration mechanism might be implemented to resolve conflicts systematically.
For example, masters may compete for the bus using a priority scheme, ensuring that higher-priority masters get bus access.
It’s important to note that the exact implementation of mode fault detection can vary between different SPI controllers and systems. Some SPI controllers may provide dedicated pins or signals for mode fault reporting, while others may rely on status registers or interrupts to inform the master about the collision.
rahulvala@gmail.com
Freelancer/verification engineer
https://www.linkedin.com/in/rahulvala/
