I am creating a custom_report_server class by extending the uvm_report_server class.
I’d like to highlight the message tags based on their severity. For example, in the below code snippet from my custom “compose_message” function, I am highlighting the “UVM_ERROR” tag in Red.
// more code
end else if (severity_type.name()=="UVM_ERROR") begin
severity_str = $sformatf(" \033[0;37;41m%s\033[0m", "UVM_ERROR");
// more code
This works and looks great when reviewing the printed messages live in terminal/stdout.
But the problem is that the ANSI color codes get printed in the simulation log file too and so the log looks very cluttered with the “\033[0;37;41mUVM_ERROR\033[0m” strings.
Is there a way to specify ANSI color coded formatting only for the stdout messages and non-color-coded messages for the stream that is logged to files?
I couldn’t find an inbuilt way to colorize the stdout but not the log file.
But this solution has been working for me:
Do perl -pi -e ‘s/\e[\d+(?>(;\d+)*)m//g’ $logfile in your simulation script after the sim finishes. So initially as long as the sim is running both stdout and $logfile will have the color codes. But after the sim, those codes will be removed from $logfile using that perl oneliner.
since you are already customizing the report server,
I would suggest trying to overload the f_display function in the uvm_report_server.
this function :
// f_display
// This method sends string severity to the command line if file is 0 and to
// the file(s) specified by file if it is not 0.
function void f_display(UVM_FILE file, string str);
if (file == 0)
$display(“%s”, str);
$fdisplay(file, “%s”, str);
can be overridden by either this :
if (file == 0)
$display(“%s” ,str);
$fdisplay(file, “%s”, strip_ansi(str));
and implement an strip_ansi function that looks for and removes the ansi sequences from the string.
// more code
// more code
Thanks!
Kaushal Modi
