this is the URL of the my code at EDA playground
In case you don’t have access, below code demonstrate the problem and output
// Example of using SystemVerilog DPI-C with C++ code.
// In EDA Playground, when using ModelSim,
// any *.cc file will be compiled as C++ and linked into the simulation.
module automatic test;
import "DPI-C" function int tb_sm_io(inout logic[31:0] data_buf[],input int device_addr,input int size,input int direction);
initial run();
task run();
logic a = 1'bx;
logic [31:0] pay_load_data[];
int result;
pay_load_data = new[3];
pay_load_data[0]=32'h12345678;
pay_load_data[1]=32'h87654321;
pay_load_data[2]=32'hDEADBEEF;
$display("Before 1st call to tb_sm_io \n\tSV: pay_load_data[0]=%x",pay_load_data[0]);
$display("\tSV: pay_load_data[1]=%x",pay_load_data[1]);
$display("\tSV: pay_load_data[2]=%x",pay_load_data[2]);
result=tb_sm_io(pay_load_data,pay_load_data[0],pay_load_data[1],pay_load_data[2]);
$display("After return from 1st call to tb_sm_io\n\tSV: pay_load_data[0]=%x",pay_load_data[0]);
//C
// This file is compiled as C++ and linked with stdlib
// into the simulation executable.
#include <iostream>
#include <svdpi.h>
#include <stdio.h>
#include <assert.h>
using namespace std;
#define cdump(x) printf("\tC: %s=%x\n",#x,x)
extern "C" int tb_sm_io(svOpenArrayHandle data_buf_ref,int device_addr,int size,int direction)
unsigned int *pay_load_data=(unsigned int *)svGetArrayPtr(data_buf_ref);
printf("Data Dump in C/%s pay_load_data=%p\n",__FUNCTION__,pay_load_data);
cdump(pay_load_data[0]);
//expect 0x87654321 == pay_load_data[1]
cdump(pay_load_data[1]);
assert(0x87654321 == pay_load_data[1]);
cdump(pay_load_data[2]);
pay_load_data[0]=pay_load_data[2];
pay_load_data[1]=0x01234567;
pay_load_data[2]=0x84219751;
cdump(device_addr);
cdump(size);
cdump(direction);
return 0;
//Result:
SV: pay_load_data[0]=12345678
SV: pay_load_data[1]=87654321
SV: pay_load_data[2]=deadbeef
Data Dump in C/tb_sm_io pay_load_data=0xefd6efe0
C: pay_load_data[0]=12345678
C: pay_load_data[1]=0
simv: …/my_dpi.cc:17: int tb_sm_io(svOpenArrayHandle, int, int, int): Assertion `0x87654321 == pay_load_data[1]’ failed.
An unexpected termination has occurred in ./simv due to a signal: Aborted
